'01 Blazer A/C problem.
Old May 2, 2014 | 11:35 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Default '01 Blazer A/C problem.
A couple of weeks ago, my Blazer started blowing warm air from the vents. I assumed it was low on freon so I checked high side pressure with the gauge have and it was hitting 600+ psi and the compressor would cut off in about 5 seconds. I replaced the orifice tube in case it was clogged and accumulator in case the desiccant busted and was getting into the system. Neither helped the issue. I recharged with less than one 12oz can and it's still doing the same thing. Which leads me to believe still an obstruction in the system. How can I flush this without a vacuum pump? Any other suggestions? Thanks.
Old May 2, 2014 | 11:36 PM
ssean92's Avatar
ssean92 is on a distinguished road
I know the ac shops around here will suck out all the freon you have in the system and vac the system for free, and only charge a small amount to top it off. Might be worth a call to see.
hotrodsbyg
Aug 15, 2011 11:47 AM
96realwe
Dec 10, 2010 09:19 AM
English5
Jul 16, 2010 11:11 AM
Confuused69
Aug 2, 2009 11:53 PM
Daytripper540
Mar 29, 2007 03:54 PM
