01 Blazer with a list of ABS codes
Old Jul 25, 2021 | 04:38 PM
61_FL_Apache's Avatar
61_FL_Apache is on a distinguished road
Default 01 Blazer with a list of ABS codes
Hello all,
My daughter has a 01 Blazer 4D 2WD with a list of ABS codes. From what I have searched so far, the most likely issues are the solder contacts inside the ECBM. Sometimes you can go a day and not see the ABS and Brake light lit. Other times, they will stay on for days.
I did check the 2 pin connector that is a possible cause too and it looks fine.
Here is the list of codes I pulled today. 265, 241, 245, 251, 246, 242, 252.
Thank you for any advise!
Steve
Old Jul 25, 2021 | 10:16 PM
GeorgeLG's Avatar
Yes, looks like you have an EBCM issue. I would:
Check the ABS fuse 60A in the underhood fuse block
Check the module ground which is G106 behind the left headlamp
Check the connector to the module
If that does not do it then you can remove the module and reflow all of the large solder joints or send it in for a rework or get a replacement module.
George
Old Jul 27, 2021 | 11:11 AM
Thank you George. I will look at those areas this weekend.
Old Aug 3, 2021 | 12:52 AM
RedValor's Avatar
RedValor is on a distinguished road
I've been having ABS problems on my 2002 for the past 3 years now. Has been next to impossible to diagnose. I don't remember the codes, but the main issue has been something eletrical circuit with the main module, and then later something with the passenger-side speed sensor. I replaced both speed sensors and not the ABS light is intermittent.
run_girl
Nov 7, 2016 02:32 PM
tb30570
Oct 1, 2016 10:28 PM
DarkRose
Aug 18, 2011 04:31 PM
xgiovannix12
Jun 28, 2011 01:10 AM
SWATPARAMEDIC
Sep 14, 2010 02:18 PM
