01 blazer warm heat only
Old Jan 7, 2013 | 09:15 AM
aa21830's Avatar
aa21830 is on a distinguished road
Yes, this usually means the coolant isn't able to make it through the core. Both hoses should be hot (or at least warm).
Old Jan 7, 2013 | 10:27 AM
Curt B's Avatar
Curt B is on a distinguished road
Originally Posted by LannyL81
There must be air in the cooling system and the suggestions above are to burp the cooling system.
I am still in the process of getting the air out in my '02 Blazer after leaving one heater hose clamp off which resulted in pumping most of the coolant out.
I am quite amazed at how much air is trapped; I have filled the radiator to the top, added coolant to the reservoir and then go for a drive; come back and check....coolant low....have done this three times now.
Just to give you an idea that it takes several heat cycles to remove the air. Keep after it and you should get nice hot air.....unless the heater core is mostly blocked....and that is a whole new story.
Good Luck
Wedging an aspirin in the thermostat will usually hold it open long enough to purge all air from the system. Gotta agree the first place to start is flushing the heater core.
Old Jan 7, 2013 | 02:20 PM
Twip's Avatar
well i just fixed this in my work blazer before i came out to Utah. and thank goodness i did. it was cold in Salt Lake City. anyway, i had the same problem, passenger hose was hot and driver was cold. i took the passenger side hose off the engine and put it in an old milk jug, then i took the driver side hose off the heater core and got a piece of 5/8'' hose. (its what i had laying around) put the 5/8 hose on the heater and blew into it gently. it took a couple of times but then i got some fluid out of the other side into the milk jug. full of all kinds of crap. put it all back together and fill with fluid. works better now, but not as hot as my other blazer. it will need a core soon, but not until it leaks. i was down in -15 and still warm and toasty. hopefully you have the same luck.
Old Jan 7, 2013 | 05:34 PM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
Originally Posted by PogiMoto
what sucks is that the hose is frozen under snow right now lol. I'll try tomorrow to run water through again, but any other suggestions? From the two coolant hoses plugged to the heater for with one cold and hot, does that say the heater core is plugged to you?
Yup the left hose is the inlet which will be hot and the right hose is the outlet which will be less hot or even cold when the core is plugged. Best to take both hoses off and flush back and forth until the water is clear. Usually have to do it once a year in my Jimmy.
Old Jan 15, 2013 | 05:32 PM
PogiMoto's Avatar
PogiMoto is on a distinguished road
Okay everyone here is an update. I finally had my garden hose not frozen and went ahead to reflush my core. Flushed it until both sides came crystal clear with water. Although I didn't see any gunk or debris come out except the dex coolant, my heater works wonderfully hot like my other blazer. (I own 2 blazers 01 & 04) Thanks everyone for your help and information!
Old Jan 15, 2013 | 06:53 PM
Cool man, glad you have heat now. I had to flush mine again last weekend and it works excellent now.
Old Jan 15, 2013 | 08:53 PM
PogiMoto's Avatar
Yeah man! A complete system flush in the spring should stop the chunks in clogging the core.
rsvensson
14
Feb 9, 2014 06:01 PM
sparky672
Nov 6, 2011 08:56 PM
jpmccr
15
Mar 9, 2011 11:13 AM
stevelknievel
Dec 23, 2008 08:50 PM
Inferno
Oct 22, 2006 08:56 PM
