01 Blazer won't start
Old Jan 22, 2018 | 08:47 AM
epierce1389's Avatar
epierce1389 is on a distinguished road
Default 01 Blazer won't start
Hello,
I have an 01 Blazer 4wd LT. I went outside to start the red dragon(yes its what i call this blazer), it tried to start, but the starter was bad. Put a new starter on and it started..waited a day or two let it go outside and it wouldn't start. It just turned and tried to start. Well I changed the battery since it was bad. Wouldn't start, just turns. Changed the ignition coil since it shocked the **** out of me. Still wouldn't start. So finally dropped the tank and changed the fuel pump..it started. Now a couple days go by, i let it sit outside and it just turns over and over. What am i missing? I've hooked it to a code reader and nothing is spiting out. At this point I am lost on where to look.
Note: At one point, the blazer would start fine if I left it in the garage, if I left it outside over night in the cold, it wouldn't start.
Old Jan 22, 2018 | 01:04 PM
I forgot to add, it does crank.
Old Jan 25, 2018 | 11:32 AM
elrobis's Avatar
elrobis is on a distinguished road
...did you change the fuel filter too?
Old Feb 10, 2018 | 08:41 PM
Sorry it took so long to get back to. I changed it today. I am letting it sit in the cold and see if it starts tomorrow.
If not where do I look next?
Old Feb 11, 2018 | 07:49 AM
well changed the fuel filter and let it sit overnight in the cold and won’t start.
Old Feb 11, 2018 | 08:09 AM
LannyL81's Avatar
How cold is cold? Sounds like the fuel is freezing.
Old Feb 11, 2018 | 09:07 AM
highs in Indiana been about 20-29, while the lows been about 10-19.
Old Feb 11, 2018 | 02:10 PM
Mike.308's Avatar
Howdy,
To split the problem between ignition and fuel, I'd take a try to inject the "engine starter" in aerosol directly to a throttle while cranking. If it cranks - You have the fuel related problem. Otherwise it's ignition.
Old Feb 11, 2018 | 02:17 PM
Originally Posted by Mike.308
Howdy,
i will do that tonight and let you know.
Old Feb 12, 2018 | 02:05 AM
GeorgeLG's Avatar
When you are having the crank but no spark condition check to see if you have 1" of strong blue spark.
George
RaDiCal_Beaver
Nov 2, 2016 07:48 PM
princered72
Sep 13, 2011 10:36 AM
Dark Rider
Aug 8, 2010 11:57 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
