02 Blazer cutting out on me
Old Mar 18, 2008 | 05:18 PM
justDrivin's Avatar
justDrivin is an unknown quantity at this point
Default 02 Blazer cutting out on me
I have replaced the catalytic converter, distributer, cap and rotor. I have changed plugs, and wires. My 02 Blazer cuts out on me when I have been driving for around an hour or two. It will start, but acts like it is flooding when I hit the gas, when it cools down, it starts right up and goes on. What to do?
Old Mar 18, 2008 | 06:29 PM
Default RE: 02 Blazer cutting out on me
I would start by having the ICM tested repeatedly to make sure that it gets hot during the testing. Most autoparts stores can test the ICM for you, but you will need to remove it.
Old Mar 18, 2008 | 07:45 PM
justDrivin's Avatar
Thanks for the advice, I will do that this weekend and post back.
Old Mar 18, 2008 | 07:58 PM
justDrivin's Avatar
Sorry for my dumbness , but where is the ICM located?
Old Mar 18, 2008 | 08:01 PM
Directly ahead of the coil bolted to a bracket with a heat sink on the other side.
Old Mar 18, 2008 | 08:57 PM
justDrivin's Avatar
ok thanks again!
Old Mar 21, 2008 | 05:53 PM
gjkmecik's Avatar
gjkmecik is an unknown quantity at this point
Replace your fuel filter. That sounds like what happened to mine. I had to replace my fuel pump too because I let it go for too long. So you can check that too.
Old Mar 21, 2008 | 07:01 PM
justDrivin's Avatar
yeah the fuel filter sounds like a good idea, thanks
Old Apr 7, 2008 | 06:13 PM
justDrivin's Avatar
I replaced the ICM, and thought it had fixed it, but today it cut out on me again. I guess i will try the fuel filter now.
1996BlazerSD605
Jul 15, 2011 03:56 PM
cbh84
Dec 15, 2010 05:52 PM
greg94
20
Aug 31, 2010 12:57 AM
rlott43
May 10, 2009 06:30 PM
xtreme01blzr
Oct 18, 2006 03:23 AM
