02 Blazer post-heater core coolant issue, help!?
Old Jan 7, 2012 | 05:34 PM
zomz's Avatar
zomz is on a distinguished road
Default 02 Blazer post-heater core coolant issue, help!?
I just got done switching out the heater core in my 2002 Blazer ZR2, and am now trying to finish up and fill the coolant. I can't seem to get more than a gallon or maybe gallon and a half in. I tried starting it to try and get it to start circulating through the engine, but the temp came up high (~240 F) within 2 minutes or so and I had to shut it off. Also, there is no sign of heat but I sort of expect that since it doesn't seem to really be circulating anything. What could be the cause? I'm stumped as to why it won't take it?
Thanks!
Old Jan 7, 2012 | 09:08 PM
warthogdriver's Avatar
Did you flush the coolant system? Sounds like a circulation issue...
Old Jan 7, 2012 | 09:43 PM
xgiovannix12's Avatar
try flushing the heater core
its worth a try
Old Jan 9, 2012 | 08:09 AM
BB3439's Avatar
BB3439 is on a distinguished road
Vapor-lock in the heater? Try loosening the heater return hose, then running the engine until coolant flows from the hose.
Old Jan 10, 2012 | 11:14 AM
zomz's Avatar
Thanks for the input guys. I ended up pulling the return line off the heater core and connected the hose to the flush out fitting on the inlet to bleed the new core. I also parked the front end up the bank in front of my house to get the rad up as the highest point and this got tons of air out. I could hear the gurgling sound in the truck. All seems good now.
BlackBeauty43
Jan 14, 2014 12:15 AM
Rodzilla
Nov 22, 2010 07:35 PM
streblo
16
Nov 6, 2010 07:46 PM
KdogTN
Sep 28, 2008 05:38 PM
calgsblaza
Feb 12, 2008 12:51 AM
