02 with coolant smell
The reason I suggested checking the coolant level cold is that when it's hot, it expands and you have a higher coolant level, if you check it cold and the level is lower, you can add coolant.
Yes you can put a dye into the coolant and check foer leaks with a black light ( and yellow sunglasses). With the dye, even if you ccan't see a leak it's easier to see the stains where the leak was before it dried up.
If it's not running hot, just make sure to carry a jug of coolant with you like junkmonkey suggested.
Have you checked the raditor cap for pressure??? This could be your problem...
dennday67
04-10-2011 01:58 PM
chrisblaze
05-23-2009 02:21 PM
dimmuborgir6nik6
05-16-2009 11:39 PM
