02 with coolant smell
Old Dec 2, 2006 | 02:35 AM
Chevy Lover's Avatar
Default RE: 02 with coolant smell
The reason I suggested checking the coolant level cold is that when it's hot, it expands and you have a higher coolant level, if you check it cold and the level is lower, you can add coolant.
Yes you can put a dye into the coolant and check foer leaks with a black light ( and yellow sunglasses). With the dye, even if you ccan't see a leak it's easier to see the stains where the leak was before it dried up.
If it's not running hot, just make sure to carry a jug of coolant with you like junkmonkey suggested.
Old Dec 5, 2006 | 08:07 PM
20Blazer00's Avatar
Have you checked the raditor cap for pressure??? This could be your problem...
03chevyblaze
Jun 25, 2012 09:37 PM
dennday67
Apr 10, 2011 01:58 PM
hfxblazer
Mar 23, 2011 04:54 PM
chrisblaze
May 23, 2009 02:21 PM
dimmuborgir6nik6
May 16, 2009 11:39 PM
