03 engine going into 98 blazer questions
Old Aug 17, 2011 | 02:32 PM
dreu62's Avatar
dreu62 is on a distinguished road
Default 03 engine going into 98 blazer questions
I need new engine for my 98 blazer and have found an 03 engine low miles. I have been told that bolts on back of block are metric, that hole needs to be drilled and tapped 1/4 npt for sensor, intake needs to be taken off old engine and put on new 03, old engine has egr and new engine does not and what should I do? I think this is all I was told. Does anyone have info on other things that need to be done to make the 03 fit.
Thanks dreu62
Old Aug 17, 2011 | 03:01 PM
Drill out the hole in the bell housing where the knock sensor attaches & tap it to 1/4" NPT. Swap over your intake manifold, but keep the injection spider from the new engine. All you need to swap is the lower intake. Everything else should be good.
Old Sep 11, 2011 | 08:07 AM
Mike-buggsbuggy's Avatar
Mike-buggsbuggy is on a distinguished road
Default Similiar question
CAn I put the engine from a 00 4wd in my 98 2wd
Old Sep 11, 2011 | 09:06 AM
DaddysBlazer's Avatar
DaddysBlazer is an unknown quantity at this point
I put an 02 motor in my 98 and all I did was tap the block for the knock senser. I didnt change the exhaust manifold or the intake manifold because I didnt want any thing to do with that stupid EGR vavle that little bugger was nothing but trouble.. The only down side to this is the SES light will always be on but every truck I have ever owned has had the light on so It didnt matter to me. If you change one of them you have to change both of them because of a three quarter inch hose that runs from the intake manifold to the exhaust manifold. So both or neither that is the question .Light or posibly no light is the other one.
Chase Clouser
Jan 24, 2014 04:36 PM
kirkito
Dec 30, 2013 08:27 PM
Schm
16
Nov 26, 2011 10:21 AM
randrm
Jan 25, 2011 02:51 PM
BOTTLEDZ28
Dec 3, 2007 08:18 AM
