10 second crank to start
Old Aug 23, 2007 | 11:50 PM
huskerinaz's Avatar
huskerinaz is an unknown quantity at this point
Default 10 second crank to start
I have a 01 with auto 4x4 to start it takes aprox. 10second cranks my truck has 60k
Old Aug 24, 2007 | 12:06 AM
rriddle3's Avatar
Default RE: 10 second crank to start
Does the cranking speed sound the same as it used to, or does it sound slower?
Old Aug 24, 2007 | 07:36 AM
If it sounds slower, I would recommend that you have your battery and charging system checked.
Old Aug 24, 2007 | 07:48 PM
huskerinaz's Avatar
No it cranks over normal just takes a long time to fire up
Old Aug 24, 2007 | 11:17 PM
rriddle3's Avatar
Perhaps the starter or fuel delivery system.
Old Nov 24, 2007 | 08:45 PM
huskerinaz's Avatar
I was told the fuel regulator was probably bad leaking fuel into the system. Where is the regulator?
Old Nov 24, 2007 | 09:01 PM
FPR failures are not typical on the newer SCFI engines. The FPR is located on the back of the injection spider under the upper intake plenum. I would first verify fuel pressure as well as run a leak down test. Both tests require a fuel pressure gauge which can be purchased from pretty much any autoparts store for $30-$40. Your engine needs 55-60psi to start and shouldn't lose pressure once the key is turned to off. A few psi over 5-10 minutes is typical, but it should never drop to zero. If you wait until the fuel pump cycles before moving from 'RUN' to 'START' with the key, does it start faster? What if you key to 'RUN' for 10 seconds, 'OFF' for 2 seconds, then 'RUN' for another 10 seconds before moving to 'START', does that make a difference? Either of these would indicate that something is allowing the fuel pressure to leak down.
Maybe it could be some carbon gunk on the IAC valve causing it to stick and not open up properly when attempting to start. If you crack the throttle with your foot, will it start faster?
Hope this helps.
Old Nov 25, 2007 | 12:46 PM
huskerinaz's Avatar
It seems to help if you crack the throtle. Where is the IAC valve?
Old Nov 25, 2007 | 01:50 PM
The IAC valve is located at the back of the throttle body. If you are going to be cleaning things, its best just to remove the throttle body and give it a good cleaning. You don't need to remove the TPS sensor (off one end of the throttle shaft), but the IAC will need to be removed. I use an old tooth brush to clean the different passages in the TB. I will warn you though, the only difficult part of removing the TB is the little plastic clip on the cruise control cable. In my experiences with it, the darn thing just pings off and goes who knows where. Its a pain for sure, but if you're careful, you shouldn't have a problem.
Old Nov 25, 2007 | 08:50 PM
huskerinaz's Avatar
Ok I cleaned everything, is the IAC vavle stiff? I could move it but it was tough. Anyway cleaned it andthe TB. Still takes quite a few cranks to start.
