1995 blazer 4.3 votec
Old Aug 30, 2005 | 02:39 PM
blaze1925's Avatar
blaze1925 is an unknown quantity at this point
Default 1995 blazer 4.3 votec
my blazer burnt out the coil, i replaced it and it burned out 4 more. i replaced the computer and flashed it, timing chain, complete distributor, control module fuel pump and wiring to fuel pump, fuel filter, water pump, my truck will run for a while and when i turn it off it wont turn on. if i check for spark the spark will ground the engine and it will turn on.
now that doesnt work. my truck wont start it cranks ok theres fuel but no dice need serious help. sos somebody please tell me something
Old Aug 31, 2005 | 12:31 PM
TONY_ton's Avatar
TONY_ton is an unknown quantity at this point
Default RE: 1995 blazer 4.3 votec
Have someone check your CFI unit thats your central fuel injection i had a similar problem maybe have it checked!
Old Aug 31, 2005 | 10:16 PM
Phatboy's Avatar
Phatboy is an unknown quantity at this point
Check all your grounds. Chasis grounds, engine grounds and computer grounds. Make sure they are connected, tight and no corrosion. You should have grounds on your fenders, frame, engine and inside the cab behind the side kick panels.
chadillac85
Mar 12, 2012 02:28 PM
shesrdy2laff
Oct 14, 2009 12:46 AM
frosajr
Sep 15, 2009 09:48 PM
STEVELINDERT
Jun 1, 2009 09:20 PM
chach3835
Engine & Internal
Dec 6, 2006 05:11 PM
