1995 Blazer 4wd Not working
Old Jun 30, 2024 | 08:41 AM
rickyd123's Avatar
rickyd123 is on a distinguished road
Default 1995 Blazer 4wd Not working
It's a 1995 and has a 4.3 liter engine and an automatic transmission. I've replaced the vacuum actuator and that didn't fix the 4wd. I've traced the vacuum lines. They are in good shape. I heard of a test where I unhook the battery for 30 minutes to test the TCCM ( Transfer Case Control Module) I did that. If the 4wd worked after 30 minutes, then the TCCM would be bad. The 4wd didn't work. Then the paper said it's probably the encoder motor. Encoder motors are very expensive. I thought I should ask the forum and see if you all agree that I have a bad encoder motor or have see if any other ideas as to what my problem is.
Old Jul 4, 2024 | 08:03 AM
rickyd123's Avatar
I discovered my Jimmy doesn't have an encoder motor. Only vehicles with push button 4wheel drive have encoder motors. Mine has a lever on the floor board to engage the 4wd. At this point the feedback I'm getting from other similar sites is the actuator switch on the side of the transfer case might be my culprit. I've checked all the vacuum lines and they're all good.
Old Jul 10, 2024 | 08:07 PM
LannyL81's Avatar
Something not right here.....the '95 Blazer 4wd did not come with a manual lever to engage the transfer case and right front axle....at least as far as I know...and I had a '95 4 door 4wd.
Yours has been modified or is not a '95.
However, the vacuum switch on the transfer case is a known failure component and a pain to access. If you remove it, be sure to mark/label those vacuum lines as to which goes where.
Good luck.
Old Dec 3, 2024 | 02:55 PM
rickyd123's Avatar
I surrendered and took it to my mechanic. It took him about 5 minutes to fix it. I've had this vacuum line unhooked that I can't figure out where it goes. He knew where it went. He had to feel for it, but once he hooked it up my 4wd worked fine.
seanie vw
Nov 28, 2017 07:40 AM
bugsbunny16374
16
May 14, 2014 07:01 AM
rectifier
Mar 26, 2014 12:34 AM
jcw67
Jan 16, 2011 10:04 AM
tk928
Oct 14, 2009 07:59 PM
