1995 Blazer Brakes
Old Jul 15, 2012 | 08:37 PM
Reed185's Avatar
Reed185 is on a distinguished road
Default 1995 Blazer Brakes
My blazer is real touchy when I leave the driveway in the gravel. I can just barely touch the pedal and they lock up and slide, but once I get out in the pavement they are fine, anyone know what this could be?
Old Jul 15, 2012 | 09:12 PM
Front brakes? Rear brakes? Left side? Right side? What has been done recently to the brakes? Did it just start happening, or has it gradually gotten worse?
Old Jul 15, 2012 | 09:45 PM
Reed185's Avatar
Seems to be all four and I just bought it three weeks ago and its done it since then....
Old Jul 15, 2012 | 10:06 PM
If all four are locking up, the problem is something that's common to all 4 wheels.... the power brake booster would be the first place to look, then the master cylinder.
Old Jul 15, 2012 | 11:33 PM
chris015's Avatar
it may just be the rear drums. (if you have drums) its a known problem as ive found many threads on it and it happens to my dads blazer when it rains. Only thing ive found to fix it is to clean the brake dust and re adjust the brakes,even thats a hit or a miss.
Old Jul 16, 2012 | 09:05 AM
spittybays
Guest
Posts: n/a
Positive there locking and not abs going off?
Old Jul 16, 2012 | 09:08 AM
Reed185's Avatar
Thats possible as well... I am gonna take it to a buddy that works at a shop and have him look at it... Im not real good with that ABS crap... Im more of an old school car person
Old Jul 16, 2012 | 09:09 AM
Reed185's Avatar
^^^ Thats possible too... I dont know much about the ABS crap so I am gonna take it to a buddy that works at a shop and let him look at it.
Old Jul 16, 2012 | 12:05 PM
LannyL81's Avatar
A 95 has rear drum brakes.
The shoes could be adjusted to tightly and lock-up on the gravel. Pull the wheels off and use a screwdriver to loosen the rear shoes a bit. There is a hole in the drum that allows this. There is a gear inside that adjusts the shoe tension on the drum. On the driver's side: insert screwdriver so handle is low, then bring handle up. This should loosen the tension. The passenger's side is opposite.
Now I may have this backwards...so after a couple of tries, if the drum does not pull off, change direction and try again.
poertsch
Apr 23, 2016 01:05 PM
goslats
15
Jul 31, 2015 09:19 AM
mowermechanic
Jan 31, 2012 09:01 AM
218persuader
Aug 20, 2010 06:11 PM
nico389
Jun 23, 2010 12:56 AM
