1995 Blazer need quick help, compression lost
Old Jan 21, 2009 | 02:21 PM
Chesterspl's Avatar
Chesterspl is an unknown quantity at this point
Default 1995 Blazer need quick help, compression lost
I have a 1995 Blazer that I am going to buy for a song and dance if I can get it running. I have changed the plugs and one plug (#2 on passenger) had an electrode broke off. Maybe a fluke, maybe running way to lean. It has recently had a tune up i.e. plugs, wires, cap, button, and such. The same cylinder that had the broke plug also has little to no compression. I put another plug in it and it didn't break that plug. It has some compression and the piston is functioning I can tell by placing my finger over the plug hole. I either have a hole in the piston or bent valve, I think. The car will run but it is a pain to get it started and will run great over 1500rpm's. I took the valve cover off and from a basic visual standpoint it mechanically seems to be cycling.
Any help would be great b/c I need this car, my household is down to one car we really need the transportation.
Can I check things out without taking the head off? Can I maybe use a plumbers camera, or should I just take the head off?
Please help guys and gals
Old Jan 21, 2009 | 02:24 PM
Default RE: 1995 Blazer need quick help, compression lost
You can put air pressure to the #2 cylinder and listen for air flowing into the intake (intake valve problem), exhaust (exhaust valve problem), or crankcase (piston/ring problem).
You may be able to use a fiber optic camera to have a look inside the cylinder, but you may not be able to see a bent valve too well from that angle.
Old Jan 21, 2009 | 02:35 PM
Chesterspl's Avatar
Brilliant, I should have thought of that. Easy way to tell. Thanks for the fast response. How can I get the motor to the combustion cycle. Bump the key or turn manually by harmonic balancer?
Old Jan 21, 2009 | 06:47 PM
If you have someone bump the starter while you hold your finger over the empty plug hole, you should be able to get it.
Old Jan 24, 2009 | 03:55 PM
Chesterspl's Avatar
Instead of posting a new post I am going to update my status. I took the head off with the thought I had a bad valve. Turns out the intake valve has a big chunk missing out of the corner. I took it out and the seat looks fine as does everything else from a visual inspection. I mic'ed the old valve and do not see that size anywhere on the net. I believe what I mic'ed was .320" and the closest I see it a .375". Maybe my mic is off but I will use another and check
My real question is, can I just order a new valve from Advance, Rockauto or anywhere and be able to put it and go or does it have to be taken to a machine shop to be seated? I have never had to replace a valve.
Any help would be great again.
(p.s. Cylinder looks fine as does piston)
Old Jan 24, 2009 | 05:08 PM
You should be able to order a new valve to just drop in. There should not be anything special about it.
At the very least, you should lap the valve and check the seat pattern.
I would pop both heads off and have them checked for flatness and a full valve job done, checking the valve guides for wear and replacing the valve seals.
jambray
Apr 6, 2015 08:02 PM
DaddysBlazer
Aug 21, 2011 08:19 PM
bigdaddykane93
Apr 30, 2010 12:45 PM
afrench690
Apr 21, 2008 02:27 PM
blazinwoody
Engine & Internal
Jan 11, 2007 05:30 PM
