1995 blazer no start
1995 Blazer 4.3L engine won’t start changed cap, rotor, coil, battery, fuel filter. Checked gas pressure 60psi with keyswitch on, holds psi ok when turned off. Engine cranks good will start sometimes and runs fine. Will restart unless sit awhile (4 to 6 hrs), then it’s back to no start. Any ideas?
not to check timing to check for spark using timing light. Since I am working on this thing alone cranking the engine and checking for spark is kinda hard. I thought that if I hooked up my timing light and taped backe the trigger switch I could place it where I could see it while trying to start the engine. Will this work or am I all wrong?
with the battery at 12.3 volts getting 46 psi fuel pressure. Put on battery charger at 12.6 volts fuel presure went to 48 psi. Left on charger a couple hours until battery voltage was at 14.1 volts fuel pressure went to 60 psi.
At which point the vehicle started, it would not at the lower pressures. I did hook up my timing light taped the trigger switch and it did show spark at the plug while cranking engine even when it would not start. Ordered the haynes manual today to get electrical prints to check for bad, corroded wires and connectors going to the feul tank. I am thinking that I
am losing voltage somewhere, and am making up the difference by charging the battery to 14 volts. Anyone ever have a problem like this?
Here's the funny thing I have a remote switch but can't seem to locate the starter relay, at least not the typical looking one.
Now it gets strange. Borrowed a scan tool & trouble shooter. With battery voltage at 12.3 volts turn key switch on fuel pump relay times out with pressure at 56 psi engine cranks but no start. Using the scanner turn on pump it goes to 62 psi engine cranks and starts.
After runing shut key switch off and shut pump off, psi at 59psi wait 15min psi at 56 psi another 5 min psi at 54 psi.
