1995 Chevrolet Blazer wont idle
Old Nov 11, 2008 | 05:14 AM
addai29's Avatar
addai29 is an unknown quantity at this point
Default 1995 Chevrolet Blazer wont idle
Anyone have any ideas on what it might be? The check engine light came on a couple weeks ago, and i had it scanned. The codes say it was just the map sensor. Now 2 weeks later,the vehicle wont even idle. The Blazer quits running as soon as i let off the gas. Any ideas? Thanks for any replies. The Blazer is a 4.3 4x4, and only has 112,000 milesif that matters.
Old Nov 11, 2008 | 08:05 AM
WolfPack's Avatar
Default RE: 1995 Chevrolet Blazer wont idle
Did you do anything with the MAP sensor after getting the code? Will it keep idling as long as you give it some gas?
Old Nov 11, 2008 | 08:16 AM
addai29's Avatar
ORIGINAL: WolfPack
No I didnt, because I plan on getting rid of the Blazer here soon. A map sensor shouldntaffect the idleing.And yes it will idle as long as I keep my foot on the gas. But when I let off, it will die when it goes below 900 rpms.
Old Nov 11, 2008 | 09:13 AM
WolfPack's Avatar
How do you figure a MAP sensor wouldnt effect idle? You also might want to replace the idle air control valve as a cheap test.
Old Nov 11, 2008 | 10:22 AM
At least pull the IAC valve and clean it. While you are cleaning things, remove the EGR valve and give it a thorough cleaning as well. Use a new, screened EGR gasket when reinstalling it.
And I do not follow your reasoning for not doing anything with the MAP sensor. It is what is responsible for the fuel injection and spark timing in the engine. Sure it could cause a problem when at idle.
Old Nov 11, 2008 | 10:23 AM
addai29's Avatar
ORIGINAL: WolfPack
I guess I was thinking of the MAF sensor, thought the MAP sensor was something different. Where exactly isthe MAP sensor located?How difficult would it be to replace, is it hard to get to?Or do I just plug it in?Im on a few restrictions for the time being. I had a surgery recently, and was put on a wound vac machine for my infection.
Old Nov 11, 2008 | 10:35 AM
The 95 does not have a MAF sensor, but if it did, it certainly would have an impact on idle quality as well.
The MAP sensor is located off the driver side of the throttle body, bolted down from the top using two small screws. See the illustration below:
Old Nov 11, 2008 | 10:47 AM
addai29's Avatar
ORIGINAL: swartlkk
Yeah I thoughtit had aMAF sensor. Thanks for the diagram. Ill let you all know if that fixed the problem.
chevyblazer9588
Nov 20, 2012 10:40 PM
chevyblazer9588
Dec 11, 2011 02:38 AM
chevyblazer9588
Aug 23, 2011 08:51 AM
gdwatson@sc.rr.com
Jul 22, 2009 09:05 PM
