1995 chevy blazer lower intake manifold
i have a 1995 chevy blazer with the 4.3 v-6 in it with CPI injection and when i removed the lower intake manifold i saw the coolant passage at front of it open all the way looked to the rear of manifold and there is what appears to be a rear coolant passge but both ports are plugged solid with some type of debris . has anyone else encountered this and if so can it be cleaned out or is it time for a new lower manifold. thanks in advance for any input
Take a look at the LIM itself. There is no rear cross-over tube in the manifold, just indentations. Clean things up as best you can. The problem wouldn't happen so much if the gasket wasn't blocked off over that port.
thanks for the information guys you just saved me a major headache . in locating a new manifold. i think they should have made a complete gasket in stead of having the hole there as if there was a port. thanks again
pshtr
04-16-2012 09:54 AM
Kknd310
16
03-27-2012 06:16 PM
ded2klf
11-29-2010 10:15 PM
vagnozzi
09-14-2007 08:40 AM
