1996 Blazer - NO AIR BLOWS
Old Feb 9, 2010 | 03:40 PM
rekrap95's Avatar
rekrap95 is on a distinguished road
Default 1996 Blazer - NO AIR BLOWS
up until yesterday i have had no problems with making heat/ac. hopped in and fired it up to get warm then realized no air was blowing through the vents. i started driving and the fan kicked in and things were fine again. next time i hopped in and drove and away though, nothing and still nothing.
i changed the fuse but no dice. im assuming something is loose? im in jersey, we just got hit with the monster blizzard and more is on the way tonight. i cannot afford to not have heat. thanks for the help in advance...
Old Feb 9, 2010 | 03:47 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
when the motor is not working turn the setting to blow high, then pop your hood and tap (NOT HAMMER) on the motor casing if it starts to work then you need a new blower motor, if not then check for power and ground at the connector with a multimeter.
Old Feb 9, 2010 | 04:57 PM
So it isn't working on any fan setting?
Old Feb 10, 2010 | 06:24 PM
rekrap95's Avatar
no it does not work on any fan setting.
Old Feb 10, 2010 | 06:29 PM
If you put power to cavity corresponding to pin 30 on the blower motor relay, will the blower motor run?
Here's the schematic for your blower motor:
Old Feb 10, 2010 | 07:52 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
sounds like a loose connection or a weak blower motor. if you do have to replace the blower motor, i know you have to cut the plastic box apart, remove old motor, install new and then glue the plastic case back together, try what kyle said first.
FT III
Jun 29, 2015 09:51 PM
Earz86
Jan 18, 2014 07:01 AM
j_o_s_h
Aug 28, 2013 02:40 PM
propbreaker
Nov 19, 2010 07:49 AM
sprbld417
Aug 29, 2010 08:43 PM
