1996 Chevrolet Blazer 4.3L Rebuild Help..
Alright I am hoping I am posting this in the right place. Heres the details.
1996 Chevrolet Blazer lt 4.3L 4x4 2" Body Lift 124K
December 2008 - I dropped a valve and the truck was down. I parked it.
Febuary 2009 - June 2009 - I removed the motor and rebuilt it. Took time to have the funds.
July 2009 - I just re-installed the motor. Its bolted down, I have to assemble the entire front belt system, Install starter, I got to change a few sensors, hook up fuel lines, etc etc etc.
I have the entire wiring harness unplugged from the motor. Thinking about it now I should have marked all the plugs but I didn't like a dummy. I need some assistance with a diagram, or pictures or something. There is a assload of wires here and honestly I can't remember where they all go. This has taken me longer than I hoped to do so my memory isn't all that great plus I had a jackasses help removing it and now I can't get ahold of him and he helped me remove the harness.
I am not concerned with the plug in connectors (they only go in 1 spot although a diagram would be nice). I am more concerned with any ground straps that were bolted and any wires not containing a plug.
This jackass friend also helped me lose a few bolts so its gonna be a fun assembly. Anyways hopefully I can finish the beast get her running and lift her up some more for 33's. At the moment I need to get the motor in.
Cliff Notes -
I need a wiring diagram, some pictures of your 4.3L wiring connections and pictures of any bolted ground straps, etc. Anything with and without a plug!
Thanks so much and sorry for the extremely long post.
Cliff Notes -
There are 3 ground straps that bolt on the back of each head and a battery ground to the block lower left (looking at engine)..Lay the harness around the valve covers and you will see it's easy, every plug-in is different and can only fit to its mate lol..Hope this helps
soky25
Mar 12, 2010 04:52 AM
88s10Blazer
Dec 25, 2007 09:29 PM
