1996 Jimmy - Cant get fluid to rear brakes
Old 05-25-2012, 09:30 PM
bgonzo's Avatar
bgonzo is on a distinguished road
Default 1996 Jimmy - Cant get fluid to rear brakes
It seems like the rear brakes are not working on my 1996 Jimmy. It takes much more pedal pressure than normal to stop the vehicle. When I tried to bleed the brakes, I could only get a little bit of fluid to come out of the rear bleeders (the fronts were fine). Is there a trick to bleeding the system on these? Could it be the master cyclinder? any other suggestions?
Old 05-25-2012, 09:58 PM
ojibwe_guy's Avatar
ojibwe_guy is on a distinguished road
My guess would be the master cylinder.
Old 05-26-2012, 06:39 PM
bgonzo's Avatar
What would cause this? Is there something in the master that could get stuck?
Old 05-26-2012, 06:49 PM
slowsinglecam's Avatar
slowsinglecam is on a distinguished road
Could be the MC. It has two lines one going to the front and one going to the rear. Maybe the seal went out for that one and only the front is working.
Old 05-28-2012, 10:22 PM
bgonzo's Avatar
If there was a bad seal in the Master Cylinder, wouldnt the pedal go to the floor? Could it be a proportioning valve problem? How do I diagnose?
Old 06-22-2012, 03:20 PM
maddie's dad's Avatar
maddie's dad is on a distinguished road
I think I have the same problem on my 93 Jimmy. it takes a lot of effort to push the pedal in to stop the truck. The front pads are worn prematurely too. I don't think ABS equipped trucks have a proportioning valve. I couldn't find one on my truck. Anybody else have some ideas what our problem might be?
goslats
15
07-31-2015 09:19 AM
GaryRoe
03-29-2012 02:41 PM
Ugly_Monkey
07-15-2011 04:19 PM
218persuader
08-20-2010 06:11 PM
steve4201
03-02-2010 04:26 AM
Quick Reply: 1996 Jimmy - Cant get fluid to rear brakes
