1996 LT Blazer 4X4 Auto,,idling to stall engine
![Exclamation](https://blazerforum.com/forum/images/icons/icon4.gif)
Hi all,,i have change the fuel pump and regulator + fuel filter,,,for some reason after i change my regulator the engine would stall @ idle, but okay when driving???any input would be apreciated,,thank you
Just because parts are new doesn't guarantee that they're good. Recheck fuel pressure and leakdown, this thread tells you how to check it: https://blazerforum.com/forum/showthread.php?t=45941
If it's OK, the Idle Air Controller, (IAC) might need to be reset with a capable scan tool.
when i change my fuel regulator i did Not replace any gaskets,they seem okay,,,should i get new gaskets and O rings and re-due the job?thanks
one more? if i disconect battery will it reset the Idle Air Controller?thanks for all your help
Last edited by swartlkk; 11-21-2010 at 02:52 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Always a good idea to replace the gaskets and O rings when removing the plenum along with using the correct tightening sequence and torque specs. Disconnecting the battery will not reset the IAC. It requires a bidirectional scan tool to access the IAC reset function.
Thank you Captain Hook,very heplful,will post after i redue the job
![Thumbs up](https://blazerforum.com/forum/images/icons/icon14.gif)
Thank again Captain Hook,i buy gasket kit for the spider and replace all and now idle back normal,no more stalling,,yes,,,,Thanks all
![Icon Bike](https://blazerforum.com/forum/images/smilies/icon_bike.gif)
pselby007@yahoo.com
11-29-2014 08:03 PM
Muscrat
06-12-2014 08:48 PM
kstanley
08-02-2009 10:32 PM
