1996 s10 diff problem
Old Dec 31, 2008 | 12:13 AM
bigdevo82's Avatar
bigdevo82 is an unknown quantity at this point
Default 1996 s10 diff problem
my front diff has a bearinggoing outand is loosing fluid, i only need it to last me a few more weeks. i have to keep filling it but its getting worse, my question is what will happen when it finally goes.....the wheels wont lock up on me will they?
Old Dec 31, 2008 | 12:17 AM
Default RE: 1996 s10 diff problem
Depends on what bearing is going bad.
Are you sure that it is a bearing going bad or is it just blown lip seal? A lip seal is relatively easy to change.
Old Dec 31, 2008 | 12:24 AM
bigdevo82's Avatar
not an expert so i am not sure, but it makes this grinding noise especially in the 10-25 mph range, what part is the lip seal?
Old Dec 31, 2008 | 12:30 AM
It is the seal that keeps the oil in. A grinding noise is not good. The sooner you can get it fixed, the cheaper it will be. The aluminum front diff enclosures do not like bad bearings.
Old Dec 31, 2008 | 12:41 AM
bigdevo82's Avatar
dont plan on fixing it, gonna be getting a new car so i just need this to last till then, my big worry is what will happen when what ever is grinding in there ceases up or explodes......are my front wheels gonna lock up.....nothing gonna happen? i wish i could just disengage the front drive axel but im told that i cant
Old Dec 31, 2008 | 12:48 AM
Unless you have an AWD, you can disconnect the front diff by removing the front driveshaft (should not be spinning at all anyway when not in 4wd) and removing both front CV axles.
steve4201
Mar 2, 2010 04:26 AM
SPEEDIE93
Aug 5, 2009 12:44 AM
WFD28
Sep 2, 2008 01:30 PM
fueler
Feb 17, 2008 04:36 PM
hadriel
Dec 13, 2007 03:01 PM
