1997 4x4 not engaging
Old Jan 11, 2009 | 06:44 AM
woodworkewr4421's Avatar
woodworkewr4421 is an unknown quantity at this point
Default 1997 4x4 not engaging
i have a 1997 blazer . when i put it in 4hi or 4lo the light or lights will light .which ever i am in . the front tires wont spin.only the back tires spin.what and how do i check this problem out.thanks for your help
Old Jan 11, 2009 | 09:15 AM
Default RE: 1997 4x4 not engaging
Start with a search of the forum. The most common cause is a problem with the front axle actuator. Either it is not getting vacuum (bad switch in the transfer case or a cut vacuum line), it has a cut in the diaphragm, the cable is seized up, or there is a problem in the collar/gears inside the front passenger axle tube.
Old Jan 11, 2009 | 09:46 AM
russm's Avatar
russm is an unknown quantity at this point
Know anyone that carries that cable ? We got mine stuck on my lake lot and had to pull it sideways. As we pulled the part ot the axle where the cable goes in caught a rock and I guess stretched the cable. It also messed up that sensor and the little plate with the three bolts that holds the cable in the axle. I actually need those 3 parts. I have lifted my truck since that little accident. I need my 4wd working though. Thanx !
seriosbrad
Nov 7, 2015 09:08 PM
chrisblaze
Dec 6, 2009 12:27 AM
TheBrettster
Mar 31, 2007 07:24 AM
Jared
Sep 15, 2006 12:52 AM
I8URVTEC
Jul 28, 2005 06:56 PM
