1997 Blazer blinkers do not work
Old Nov 28, 2006 | 09:13 PM
athens61's Avatar
athens61 is an unknown quantity at this point
Default 1997 Blazer blinkers do not work
1997 Chevy Blazer blinkers do not work . They turn ON but do not blink
Old Nov 28, 2006 | 09:15 PM
magtec's Avatar
magtec is an unknown quantity at this point
Default RE: 1997 Blazer blinkers do not work
make sure there aren't any burned out bulbs.
Old Nov 28, 2006 | 10:09 PM
You may need to replace the relay. But yeah, check your bulbs first. If you do not have the towing package, then your relay is a load sensitive relay. Take away the load (ie blow a bulb) and it won't blink...
Old Nov 28, 2006 | 10:24 PM
magnum434's Avatar
magnum434 is an unknown quantity at this point
yes...check bulbs first because if one is out it messes up everything..but if not...then yea...itll the flasher located DIRECTLY behind the cigarette lighters. You have to remove the bottom part of the dash...its sorta hard to get to, but not too bad at all...it will kinda look like a short little dark plastic "oil filter" kinda...its about golf ball size...u just pull it out and pop the new one in...make sure u take out the right one because there are 2 different ones side by side. i think its on the right
kimb
Jan 8, 2014 11:00 AM
blazer9901
Aug 6, 2013 10:55 PM
jonlandeinthemud
Jun 8, 2011 10:09 PM
fla_blazer4x4
Dec 15, 2007 10:50 PM
ccajun4real
Nov 5, 2007 01:07 PM
