1997 Jimmy not OBD?
Old Oct 6, 2024 | 07:42 PM
97 Jimmy's Avatar
97 Jimmy is on a distinguished road
Default 1997 Jimmy not OBD?
Hello, been lurking here a while learning all I can! I've recently purchased a 1997 Jimmy 4 door and am working on getting it back into tip top shape. I've been using torque pro with the bafx Bluetooth adapter as my scan tool - I've got several issues.
1) Torque tells me that the ECU is non OBD. Is this normal?
​​​​​​2) Idle is consistently higher than it should be, around 850-900rpm, when driving it doesn't drop below 1100rpm until I apply the brakes. Seems abnormal to me, is this correct?
3) The engine is consistently running rich, long term fuel trims on both banks are showing between 15 and 20 percent.
Here's what I've done so far. Cleaned the throttle body, cleaned the MAF sensor, cleaned the EGR, cleaned the MAP. New plugs were installed about 1000km ago along with a new distributor, alternator, and upper and lower intake manifold gaskets being redone.
I'm looking for any/all advice I can get! Thanks in advance!
Old Oct 7, 2024 | 08:13 AM
GeorgeLG's Avatar
Old Oct 8, 2024 | 12:03 AM
97 Jimmy's Avatar
Originally Posted by GeorgeLG
Thanks George! I had missed the part in there where Les recommends dash command for the 97 Jimmy/blazer. I've got set up with that and will use it going forward.
lwr199
Jun 16, 2021 11:35 AM
Tmerritt
Aug 12, 2015 07:25 PM
jaronk
May 21, 2012 05:01 PM
velikiplus
May 18, 2012 12:56 PM
97cherryblazer
Jan 18, 2012 03:59 PM
