1998 Blazer 4wd Wiring Diagrams Please!
Old Dec 12, 2011 | 07:37 PM
Mark_D's Avatar
Mark_D is on a distinguished road
Thank you for the quick reply!
I thought that was what is was called, but since I could not find it in any of my go-to auto part websites I thought maybe I was wrong. What is the catalog name for this thing or does anyone know where they can be got? I'll replace that and see what happens.
Thanks again, and I'll report back soon.
Old Dec 12, 2011 | 07:51 PM
On this website, they call it a vacuum control switch but that's incorrect. The image, the part number and the price are right though. Most auto parts stores carry, or can get, Dorman parts.
Dorman OE Solutions 600-504 - Vacuum Control Switch | O'Reilly Auto Parts
EDIT:
Here's another one, and this is correct:
http://shop.advanceautoparts.com/web...5_R%7CGRP60008____
Old Dec 12, 2011 | 09:02 PM
Mark_D's Avatar
Those parts look like the same part that people list as the "Transfer Case Engagement Switch." Is this correct even though the transfer case is back by the transmission?
Old Dec 12, 2011 | 09:13 PM
They do look similar; the top one switches vacuum and the bottom one switches electricity.
This is the "Transfer Case Engagement Switch"
It's located on the transfer case and has 3 vacuum lines attached to it. It sends vacuum to the front axle actuator under the battery tray.
This is the "Front Axle Engagement Switch" and it's located on the right front axle tube. It's basically a push-button, on/off switch with two wires connected to it:
EDIT:
The top one tells the axle to engage, the bottom one tells the VCM if it actually engaged.
Old Dec 12, 2011 | 09:23 PM
Mark_D's Avatar
Thank you VERY much for your help! I just wanted to make sure that I had things straight. I am going to put a new switch in tomorrow and will post what happens.
Old Dec 12, 2011 | 10:19 PM
Mark_D's Avatar
To do my part, I took some photos of the Switch installed in the hope that it helps someone else solve a problem:
This is the 2-Pin connector that plugs into the Front Axle Engagement Switch
The red arrow shows the Front Axle Engagement Switch. The wire in the foreground is not connected to anything, it would be plugged into the Switch.
Old Dec 13, 2011 | 07:45 PM
Mark_D's Avatar
AWESOME! A new Front Axle Engagement Switch for $13.00 appears to have fixed the problem with the 4wd fuse constantly blowing as well as the problem of the temp, fuel, & outside temp gauges and gear selector light going out.
Thanks a lot for the help everybody!
Old Dec 15, 2011 | 07:47 AM
Tinted's Avatar
Tinted is on a distinguished road
great pics Mark, I always wondered where exactly that switch is.
rich27
Oct 23, 2014 01:16 AM
Dobe Rottie Gang
Aug 29, 2013 03:33 PM
chirinosca
Jul 28, 2013 06:53 PM
BlazinClinton
Oct 16, 2011 12:47 PM
chevyrocksu
Jan 3, 2007 03:04 PM
