1998 Blazer electrical problem-please help.
Old Jan 2, 2007 | 05:25 PM
chevy_kalle's Avatar
chevy_kalle is an unknown quantity at this point
Default RE: 1998 Blazer electrical problem-please help.
Thanks, no i did'nt actually clean the starter connections, but it cranks fine, is the other stuff wired from the starter? Is there someway to clean the ignition switch if its bad or do i have to replace it?
Old Jan 2, 2007 | 06:16 PM
DINO55's Avatar
DINO55 is an unknown quantity at this point
You must Replace the Ignition Switch Wireing Harness, Your's is bad...They run about $100 bucks at advanced auto... By replacing it now you will save yourself a host of problems later...
Old Jan 2, 2007 | 07:50 PM
mrartie's Avatar
mrartie is an unknown quantity at this point
Yesterday the dash lights came on and it died but started right up. I drove it for about 20 miles after that and about 50 miles today and it acted fine.
I'm still concerned but hope that was some type of fluke-since it has not done it since Xmas.
Old Jan 2, 2007 | 09:28 PM
thanks for the replies, so Dino55 i should replace only the wireing harness not the ignition switch? Is it by the way normal that you can take your key out of the ignition with the engine running?
Mgiudice
Feb 23, 2011 11:20 AM
didgeridood
Dec 27, 2010 08:50 PM
Hotfingers
May 28, 2009 07:15 AM
S10Blazer
Sep 25, 2006 03:18 AM
lowdend
Jul 26, 2006 08:35 PM
