1998 Blazer LT ELECTRICAL issues
Old Dec 20, 2007 | 10:14 PM
KIllarb634's Avatar
KIllarb634 is an unknown quantity at this point
Default 1998 Blazer LT ELECTRICAL issues
Ok here's the deal and i can't figure it out.
98 blazer lt 4wd;
Dash lights and gauges and radio go on and off at different times. I have checked all grounds from my radio and amps and everything is good. I couple times the car died but would start up again, two times it didn't turn right over but did.
all gauges lights radio flutter on and off making a clicking noise while doing it.
All ground wires are well grounded.
Battery holds charge well and negative is good.
any other ideas?
Thanks in advance
Brian
Old Dec 20, 2007 | 10:17 PM
Default RE: 1998 Blazer LT ELECTRICAL issues
Sounds like the ignition switch is on it's way out.
Old Dec 20, 2007 | 10:31 PM
KIllarb634's Avatar
wow, can't believe i didn't think of that.... Thanks
Is there any way to test it? I had a similar problem on my supra but it was the harness, is there a way to test the ign switch to rule out the ign harness?
Thanks again
Brian
sportjunkee
Jul 17, 2015 01:39 PM
JoSHN
Sep 14, 2012 04:56 PM
didgeridood
Dec 27, 2010 08:50 PM
dgreichu
Mar 23, 2008 05:06 PM
mrartie
13
Jan 2, 2007 09:28 PM
