electrical problem
Old Dec 20, 2007 | 10:19 PM
Monty75's Avatar
Monty75 is an unknown quantity at this point
Default electrical problem
I need help, I have noticed when I drive the voltimeter reads fine but then when I come to a stop with the brakes pressed the voltimeter needle goes down to about 12 and the lights dim but when I let go of the brakes and press the gas it goes up back to normal, I just had the alternator change this pass summer so I dont think thats the problem, actually today the needle came so far low that the low battery light came on. Has anybody had any problems like this?
by the way I have a 99 blazer
Old Dec 21, 2007 | 05:48 AM
drperry's Avatar
Default RE: electrical problem
Does it only do it when you're pressing the brakes?
Or does it do it when your idling in park?
Do you feel your brake pedal doing anything funky?
ABS usually makes the lights dim when it kicks in...
Old Dec 21, 2007 | 06:57 AM
Monty75's Avatar
the vehicle brakes fine, it happens when I'm at a stand still at a stop light pressing on the brakes waiting to go.
Old Dec 21, 2007 | 07:01 AM
drperry's Avatar
I'd get the battery and alternator tested, just to be on the safe side...
Otherwise you've probably got a bad ground... Make sure your battery terminals have a good connection.
JoSHN
Sep 14, 2012 04:56 PM
blazerxtreme1
Engine & Internal
Jul 7, 2006 12:46 PM
88s10Blazer
Jun 28, 2006 03:22 PM
Blazin99
Jun 12, 2006 01:15 PM
MontegoRX
Feb 15, 2006 11:30 PM
