1998 blazer rod knock on startup
Old Oct 21, 2014 | 08:52 AM
tvair450's Avatar
tvair450 is on a distinguished road
UPDATE.
Had no choice but to drive it to work this morning. Started up fine with no knock and the pressure gauge inside was reading 18 lbs at idle. Started driving and went up to about 40, went to a stop then the gauge went down to 0 and check gauge light came on. I'm going to get an oil change along with filter after work with 10w40, and getting a pressure tester and I'm starting to think the pressure sensor sender is bad. Maybe that knock was just a freak thing. I've only heard it once. If I actually had 0 pressure at idle like it indicates it would be heating up and my lifters would be making a loud racket and they weren't. Sound about right fellas?
Old Oct 21, 2014 | 06:29 PM
Might be too late, but, use 5W30 oil, not 10W30. Using thicker oil will increase oil pressure and decrease oil volume, (flow) not a good idea. Always use what the manufacturer recommends. Check the oil pressure when hot, both at idle and at 2K rpm, and let us know what you find
chaoticdopey
75
Mar 16, 2012 12:03 AM
Klturi421
Aug 2, 2011 07:21 PM
RandyRhoadsFan82
Oct 4, 2010 10:44 PM
ejschultz
Sep 25, 2009 04:05 PM
Tony H
Jul 17, 2009 08:16 AM
