Is it rod knock or something else?
Old Sep 30, 2010 | 02:34 PM
RandyRhoadsFan82's Avatar
RandyRhoadsFan82 is on a distinguished road
Default Is it rod knock or something else?
Hi guys, Im new to this forum. I just bought a 1996 Chevy Blazer LS aobut a month ago.
To get right into it, I believe Im having problems with it already. It has a replaced engine with appx. 104,000 miles on it. I hear this noise at idle but not when getting up to speed, it sounds like a rod knock. It doesnt sound "metallicy" its more of a deep sounding thud but its constant and doesnt change pitch which gets me to believe its the flywheel. So I did the test for rod knock by pulling the spark plug wires one at a time to see if it quieted down; no cigar, it just kept "thudding". I know its coming from the bottom end of the engine, when I went under there I felt underneath the oil pan and for every knock i would feel vibration on the pan. Anyone know what this noise is? Could it be the oil pump?? Thanks guys!
Old Sep 30, 2010 | 03:00 PM
Does it increase in speed when you increase the engine RPM?
Old Sep 30, 2010 | 09:15 PM
yes, but only until about 1200-1300RPM that I cant hear it. any ideas?
Old Oct 1, 2010 | 11:42 AM
If it increases with RPM and can be felt through the pan, it likely is in your bottom end. How is low RPM oil pressure? Have you put it on an actual mechanical gauge?
Old Oct 1, 2010 | 02:50 PM
robertr728's Avatar
robertr728 is on a distinguished road
I have a similar problem Check this thread and see if its what your going thru?
https://blazerforum.com/forum/engine-transmission-35/2000-blazer-4-3-knock-idle-warm-48084/
Old Oct 1, 2010 | 09:33 PM
the oil pressure is awesome, between 40-60 cold idle and at warm idle its at about 30. the weird thing is is ive been driving it for over 1,000 miles now, shouldnt it have thrown a connecting rod already?
Old Oct 4, 2010 | 10:45 AM
robertr728's Avatar
If it starts to get louder and worse then i would say its a bearing in the bottom end. Just be cautious drive it and see what happens.
Old Oct 4, 2010 | 10:44 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
possibly a thrust bearing that has worn out? The thudding could be your whole crankshaft sliding back and forth.
Klturi421
Aug 2, 2011 07:21 PM
okstud
Headers, Intake, & Exhaust
14
Feb 14, 2010 09:21 PM
sgtbrum
Dec 18, 2006 11:29 AM
mont1340
Feb 11, 2006 10:37 PM
blazergirl15
Jul 9, 2005 03:26 AM
