1998 blazer transmission & transfer case
Old Jan 28, 2011 | 06:03 PM
daneo's Avatar
daneo is on a distinguished road
Default 1998 blazer transmission & transfer case
Trans making whirring noise when put into gear. Sounds like power steering pump was going.Got under car on rack ,sound coming from front of trans. shifts alright, had trans flushed but same noise.Did not change filter,was told filter possible dirty and starving pump ? Will not shift into 4 Hi but will shift into 4 Low. Was told could be as easy as flushing and refilling transfer case ? Oh, not trans related - rubber seal around sunroof. Rubber is good, but aft side of the seal is flibbing into the roof. Water is leaking in and down to the floor. Can i heat the rubber and reset it ? Can i silicon spray it so it slips and resets on the glass ?
Flyfishen
Jun 18, 2019 11:22 AM
bensaintonge
Dec 3, 2013 08:14 AM
judgemint
Nov 30, 2010 09:28 PM
bfsmith72549
Nov 1, 2010 05:44 PM
yarinzim
13
Sep 3, 2010 08:28 PM
