1998 Hard Starting
Old Apr 12, 2007 | 09:02 PM
bm4183's Avatar
bm4183 is an unknown quantity at this point
Default 1998 Hard Starting
For awhile now my blazer (1998 4.3L) has had a hard starting issue. It turns over for about 10 to 15 seconds before it finally starts and then it runs fine and also gets good gas milage; around 18 - 21 mpg. I bought a fuel pressure gauge and it reads 62 psi when I turn the key on and then it drops to around 52 to 54 psi while its running. When I turn the engine off the fuel pressure drops rather quickly (about 30 to 45 seconds) to around 20 psi and then fairly slowly until it reaches 0. The fuel filter has been recently changed. It also has about 109,000 miles. Does this sound like the fuel pressure regulator?
Thanks,
Brandon
Old Apr 15, 2007 | 10:57 PM
bm4183's Avatar
Default RE: 1998 Hard Starting
Should I just pull the intake and check everything out?
Is there anything else I can check that might be causing this?
Anyone???
Old Apr 16, 2007 | 12:47 PM
junkmonkey's Avatar
junkmonkey is an unknown quantity at this point
Judging by your fuel pressure readings your fuel pump is working fine (you need about 60 psi to start and she drops to 50+ psi during runtime) so your OK there. It's a '98, so you have to start thinking about, plugs, wires, cap, rotor, fuel injectors dirty or leaking, fuel pressure regulator (maybe????), vacuum leaks, etc...I'd pull the intake and clean up in there. Be careful around the fuel spider, the fuel poppet nozzles can be brittle as well as the lines connecting the poppets to the injectors. Take your time around removing the fule lines in the fuel metering body, you want to note the orientation of the o-rings and metal washers as they come out (if they come out) with the fuel pipes. Use lots of carb cleaner to clean up the intake area. Have you changed out the fuel filter lately? That is a rather unpleasant job, though. Good Luck.
Old Apr 17, 2007 | 12:41 AM
throttlesteer's Avatar
throttlesteer is an unknown quantity at this point
I'd vote for trying the fuel pressure regulator. Sounds like it's a little slow to bring the pressure up to begin with. Make sure the vaccum tube leading to it doesn't have any cracks or leaks in it as well as that will make it seem like the regulator isn't doing it's job.
Old Apr 17, 2007 | 01:12 PM
vagnozzi's Avatar
vagnozzi is an unknown quantity at this point
i'm having the same issue. going to run some fuel injector cleaner through it, acting like a stuck/open injector, most likely from debris or the fuel spider....is the fuel spider really that common of an issue? I'm told it is
ZachL90
Dec 29, 2012 07:58 PM
cgrett
Nov 15, 2010 09:08 PM
9t8blazer
Jun 5, 2009 07:14 AM
Ballysto
Aug 14, 2008 06:24 PM
HaRt
Jun 12, 2005 04:15 PM
