1999 Blazer Blowing Cold Air
Old Dec 31, 2020 | 03:32 PM
Tippecanoe41's Avatar
Tippecanoe41 is on a distinguished road
Default 1999 Blazer Blowing Cold Air
So, I have a 1999 Blazer, 4wd, 4 doors, 4.3L V6, and it started blowing cold air. I noticed the temperature gauge was only reading like 140-150. I changed out the thermostat. That didn't do anything to change the temperature reading or the temperature of the air that was blowing out when I turn the heat on. What's the next most likely problem? Heater Core? Thanks for your opinions, I appreciate it.
Old Dec 31, 2020 | 10:38 PM
Mods's Avatar
99's are bad for the blend door actuator messing up. make sure the door is moving when you switch from heat to cool, you can check visually by opening the small access hatch ontop of the airbox. Circled here -
Old Dec 31, 2020 | 11:13 PM
GeorgeLG's Avatar
Welcome to the forum.
What do the 2 heater hoses feel like at the firewall when the truck is warmed up?
George
TheSaint
Nov 2, 2018 02:12 PM
daddyx2
Aug 10, 2012 12:06 AM
cjbehrens
Feb 20, 2009 12:27 PM
stevenson_ltdan
Jan 22, 2008 05:47 PM
Matty Kling
Sep 28, 2007 06:58 PM
