1999 Blazer brake pedal goes to floor
Old Aug 12, 2009 | 05:14 PM
kodie's Avatar
kodie is on a distinguished road
Default 1999 Blazer brake pedal goes to floor
I have a 1999 chevy blazer 4x4 with a 6 cyl engine. I have disc brakes all the way around. My daughter was driving the truck and had to stop suddenly. After that she had no brakes. The brake pedal goes all the way to the floor. I checked all the brakes and had to replace the rear brake pads, discs and rear passenger caliper. I bled the brakes also. The brake pedal still goes all the way to the floor when the truck is running and when the truck is not running. I cannot pump the brakes up at all. Any ideas as to why I still do not have any brakes?
Old Aug 12, 2009 | 05:49 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
have you checked all the brake lines? ive seen a few guys actually blow a line after slamming on the brakes.
Old Aug 12, 2009 | 06:10 PM
91chevywt's Avatar
91chevywt is an unknown quantity at this point
I'm wondering if maybe there would be something internally wrong with the master cylinder
Old Aug 13, 2009 | 05:06 AM
kodie's Avatar
I checked all the brake lines and there is not a leak. I'm gonna try installing a new master cylinder.
Old Aug 13, 2009 | 02:36 PM
91chevywt's Avatar
You could probably also test it by putting it in a vise and pumping it with a screwdriver to see if it moves any fluid. Maybe just a quick test before you replace it to see if you can see anything wrong with it.
Chevyblazerowner
May 14, 2015 01:36 PM
Jesse31
Jul 21, 2010 12:13 PM
jim109
May 23, 2010 05:57 PM
Kendo
Sep 24, 2009 01:12 AM
azembdriver
Nov 21, 2008 07:14 AM
