1999 Blazer ZR2. The AC is not working. Where are the most common leaks?
Old Sep 13, 2018 | 04:26 AM
TheSaint's Avatar
TheSaint will become famous soon enough
GeoregeLG. Are you thinking of the drier?
Old Sep 13, 2018 | 11:49 AM
TheSaint's Avatar
I have checked the compressor by "jumping" the relay and the compressor started at once so i guess it is either no refridgerant or it may be the low pressure switch
I suppose it is the the low pressure switch that is shown here with a white arrow in the picture?
Attached Thumbnails 1999 Blazer ZR2. The AC is not working. Where are the most common leaks?-ac-low-pressure-switch-1999-blazer-zr2.jpg
Old Sep 13, 2018 | 11:57 AM
GeorgeLG's Avatar
Now jumper the pressure switch to confirm thats the only problem. It would be best to do that with a set of gauges on the system and disconnect as soon as you see the pressures. Don't run it low on gas for an extended period.
George
Old Sep 13, 2018 | 11:59 AM
TheSaint's Avatar
GeorgeLG
And as soon as i jumped the low pressure swiych the AC compressor started at once
Attached Thumbnails 1999 Blazer ZR2. The AC is not working. Where are the most common leaks?-jump-low-pressure-switch-see-if-compressor-starts.-if-starts-low-freon.jpg
Old Sep 13, 2018 | 12:08 PM
GeorgeLG's Avatar
Yes. Thats the accumulator/dryer and has the low pressure switch attached to a schrader port.
George
Old Sep 13, 2018 | 12:14 PM
TheSaint's Avatar
And now it is working except i guess ii is low on refridgerant so i need to refill
Looks like the problem is solved
Old Sep 13, 2018 | 12:17 PM
GeorgeLG's Avatar
You need to find the leak as well.
George
Old Sep 13, 2018 | 12:37 PM
TheSaint's Avatar
I have a feeling that it is located in the in the front of the car in the condenser. I might be wrong but..
Old Sep 13, 2018 | 01:41 PM
GeorgeLG's Avatar
Most sophisticated method is an electronic leak detector. Best old school methods - feel for oil residue and a few drops of dawn in a water spray bottle around everything with pressure in the system and look for bubbles.
George
Old Sep 16, 2018 | 05:12 AM
TheSaint's Avatar
If i am lucky there is only a "weak" o-ring. Thinking of the fact that the car had been standg unused for years before i bought it.
A friend of mine have a "sniffer" that detect leaks so will check it using that tool.
Looking at the connector for refill of refridgerant it looks like the connector that i have on my air tools. What is the connector called and is it the connector shown on the pictures below?
Attached Thumbnails 1999 Blazer ZR2. The AC is not working. Where are the most common leaks?-adapter-med-manometer-etterfylling-av-kuldemedie-ebay.com-192610905990-pris-%2416.-pic-1.jpg   1999 Blazer ZR2. The AC is not working. Where are the most common leaks?-adapter-med-manometer-etterfylling-av-kuldemedie-ebay.com-192610905990-pris-%2416.-pic-2.jpg
