1999 Bravada fuel tank vent busted
Old Nov 22, 2014 | 02:01 PM
sky_blazer's Avatar
sky_blazer is on a distinguished road
Default 1999 Bravada fuel tank vent busted
title says it all, went to replace fuel pump and plastic was so brittle this little guy broke off. its on the front of the tank i think its called vent valve. the ones i find only go up to 97 mine is a 99. anybody know where i can get one and how this comes out?
Old Nov 23, 2014 | 05:43 AM
sky_blazer's Avatar
bump....
Old Nov 23, 2014 | 07:34 AM
rockinrandy's Avatar
rockinrandy is on a distinguished road
The local you pull junkyard should have one. That would be the best bet and probably the cheapest otherwise you are likely dealership bound
Old Nov 23, 2014 | 09:43 AM
sky_blazer's Avatar
do i have to replace the tank?
Old Nov 23, 2014 | 11:36 AM
perumotors1369's Avatar
perumotors1369 is on a distinguished road
yes...as far as I know that is what you have to do...and actually, as previously mentioned, this will probably be most cost effective and less BS if somehow you could change it (the valve, if at all possible)..Jerry
Old Nov 23, 2014 | 12:02 PM
sky_blazer's Avatar
its sucks cause i have no other vehicle to get another tank..i just wondered if it could be repaired. ill figure something out
Old Nov 23, 2014 | 02:43 PM
sky_blazer's Avatar
i put some JB weld on with a drill bit holding it in place it seems pretty firm. would i be ok to use it? or am i gonna encounter problems? can somebody explain the function of this valve?
Old Nov 25, 2014 | 01:18 PM
sky_blazer's Avatar
why is this tank so hard to find? i either have to pay out the a** for one or use my busted one that leaks gas. i tried all my local junkyards, Ebay, Amazon and nothing. in fact most of my local junkyards said they pull the tanks and "punch" them (scrap them) when they get a vehicle in ARGHHH!!!!
Old Nov 25, 2014 | 09:36 PM
Brass tubing (like
THIS THIS
from Amazon, but whatever size you actually need), a drill bit slightly smaller than the tubing diameter, and some JB Weld will fix that right up.
Use the drill bit to open up the hole in both the broke off piece and the piece in the tank going only about 3/8" into the tank piece to keep the tubing from covering the port down into the tank. Cut the tubing to the appropriate length. Using a small block of wood and a hammer, tap the tubing into the tank side of the connection then tap the nipple onto the tubing about half way. Coat the original crack area and the tube with JB Weld then complete the assembly.
The tubing will add the much needed support to the fitting while JB Weld will seal it all up and should keep everything together.
Old Nov 26, 2014 | 01:56 PM
sky_blazer's Avatar
Originally Posted by swartlkk
Brass tubing (like
THIS THIS
dude you are a freaking genius ^^ i owe you a beer
you should put that in a sticky or put that in DIY
