2000 4.3 AT 4wd radiator replacement
Old Jun 12, 2011 | 04:19 PM
Flatearthman's Avatar
Flatearthman is on a distinguished road
Smile 2000 4.3 AT 4wd radiator replacement
What needs to be removed to replace a radiator on a 00 blazer automatic 4wd?
Aside from coolant, fan shrouds, radiator hoses and tranny lines?
How do the tranny cooler lines come off the radiator?
They don't look like the old style fittings?
any short cuts would be appreciated
Thank's
Old Jun 14, 2011 | 11:11 AM
Are there special tools needed to remove the tranny lines on the radiator?
Do i have to remove the fan clutch?
anyone?
Old Jun 14, 2011 | 11:18 AM
They're either threaded in or the quick connect fittings. Threaded - I would use a line wrench to protect the fitting from being rounded off. Quick connect - a small screw driver is all that is needed to pop the 'e' clip off the fitting and then just pull the line out. I pretty sure that my '00 Bravada was threaded on the transmission cooler lines. The oil cooler lines (driver side) are quick connect.
You should not have to remove the fan clutch.
Common tools should get the job done.
Old Jun 14, 2011 | 05:54 PM
zeedeevil21's Avatar
zeedeevil21 is on a distinguished road
I had just replaced my radiator yesterday in my 2000 blazer 4wd. I removed upper shroud...then my clutch fan then lower shroud to gain access to drain plug and lower transmission line...all trans and oil lines were e clipped
Old Jun 15, 2011 | 01:20 PM
Thank's for the infos Guy's i was hoping i didn't have to remove the fan clutch.
I took a better look at them in the daylight and they are the quick connects.
Old Jun 15, 2011 | 01:56 PM
kristoph30's Avatar
kristoph30 is on a distinguished road
I didnt remove my fan clutch.
Jonboy
Jun 4, 2010 11:25 PM
bigdaddykane93
Jan 4, 2010 12:03 PM
scottyk
14
Mar 1, 2007 12:03 AM
BlaZeR FXB1581
Engine & Internal
Jun 30, 2006 08:46 AM
93blazerman
Engine & Internal
Apr 7, 2005 02:26 PM
