2000 4.3L Quick Vacuum question?
Old Dec 13, 2012 | 06:29 PM
davidwis's Avatar
davidwis is on a distinguished road
Default 2000 4.3L Quick Vacuum question?
Could someone please tell me where this hose goes to? The Blazer was given to me with the motor half way in, I have everything installed and good to go.... But this hose.. Thank you!
Old Dec 13, 2012 | 06:39 PM
xgiovannix12's Avatar
looks like vac hose . Possibly behind the motor by the distributor.
Old Dec 13, 2012 | 08:52 PM
Someone modified it at one point in time. It's supposed to connect to a fitting on the intake manifold, near the PCV valve fitting in the driver side rocker arm cover. It supplies vacuum for 4WD and the HVAC systems.
Old Dec 14, 2012 | 03:49 AM
J_E's Avatar
J_E
J_E is on a distinguished road
As others have mentioned, that hose goes from the intake manifold on the drivers side down to a vacuum connection for the SMOG/secondary air pump. The hose that connects to the third part of the 'T' is a 7/16" vacuum hose and runs over to the area just behind the ABS controller/ABS pump. There it connects to another 'T' then to the A/C and the Vacuum Reservoir.
Just wanted to add that the connection for the vacuum reservoir is hard to find. It is in the fender and the connection is down under the ABS pump and has to be found by feel.
cjb2145
18
Oct 6, 2018 04:46 PM
blazinwoody
Engine & Internal
Jan 11, 2007 05:30 PM
88s10Blazer
Sep 26, 2006 10:19 AM
athleticdawg26
Jul 30, 2006 02:43 AM
black19
Jul 2, 2006 11:58 PM
