2000 ac compressor help needed
the clutch is throwing metal shavings out the front of the ac compressor so the clutch needs to be replaced.
i can't find the clutch separate from the compressor so i was thinking of going to a junkyard and pulling a compressor and separating the clutch.
what year compressors will work? and do other vehicles use the same compressor as the 2000 blazer.
thanks
thanks
oreilys has just the clutch but its a lil expinsive. you can get them from an older blazer down too 96 i think
Been there, tried that. Dont bother.. if you stress the replacement pulley in the least getting it off you'll be right back in the same boat.
Call autozone
667655 Alternate Part Number: 668655
Warranty: 3 MO
$80
Part Number: 48655
Warranty: 3 MO
$110
Most those are in the reg dist centers. Ask where it is. I drove.
I think NAPA has them at $120 or so. Also prob in dist centers
Look out for this:
![Name: gA7HH.jpg
Size: 41.0 KB](https://blazerforum.com/forum/attachments/2nd-generation-s-series-1995-2005-tech-41/38444d1683047922-2000-ac-compressor-help-needed-ga7hh.jpg)
Needs 1/2 " shorter belt
Call autozone
Warranty: 3 MO
$80
Part Number: 48655
Warranty: 3 MO
$110
Look out for this:
![Name: gA7HH.jpg
were did you find the special tool to take it off too. the parts store should have it but oreilys couldn't find it the last time i was there.
I got mine off amazon for $25.. It was my bearing going bad so I had some time. Autozone doesnt sell them so you cant use the 'takeback' program.
You might just want to try the delete pulley and belt, tie the compressor SECURELY off to the side. Still cheaper than opening up the system in the long run.
well the plan is to get it fixed before friday because its getting traded in.
![Icon Frown](https://blazerforum.com/forum/images/smilies/icon_frown.gif)
Well.. I'm glad you dont do like most guys would and go to junkyard and get a compressor and just dump the gas in it , then fill it back up without proper procedure.
Sure.. it'll cool for a while esp if the lines arent disconnected long, and seem great but probably fail in a year or two and the next guy will have to replace almost everything
i might pick up the bearing too and see if it's just that. i'll buy both and see what one it is.
i might not be trading it in either. i had a guy call me and wants to trade me another vehicle so we'll see. but regardless it needs to get fixed
Trust me.. If you dont have a press, and you're not real careful that is NOT a good idea. How do you think I learned how fragile those clutch pulley faces are?
I had a press, made one little slip. Ruined.
Found two other compressors to take clutches.. both had been dropped and pulley web broken.
The next best idea is to get a used compressor, swap clutches and take back as core.
Check amazon for the tool
Amazon.com: Astro Pneumatic 7886 A/C Compressor Clutch Installer/Remover Kit: Home Improvement
I have a compressor off a 2000 Jimmy. Let me know if your interested - shoot me a PM.
wallacereid
01-09-2012 12:34 PM
frodiggs
05-03-2011 10:33 PM
gmcjimmy_94
12-30-2010 12:37 AM
JayStumble
12-12-2010 07:29 PM
