2000 blazer 2wd 2 door wont start
i got 2000 blazer 2dr 2wd. wont start, died in the snow, when turn key nothing, got power radio lights, but no crank at all, i was try too get of my drive way and it died and now im puzzled. dont know where too start. got power no crank at all, like a bad starter but cant be, it died when i was backing it up.
Have done all the obvious things? Have you checked all the fuses to make sure they are good? Have you checked the battery connections and make sure they are free of corrosion and tight? Do the instrument panel lights dim when you try starting it?
Later, Doug
Later, Doug
You have +12V at the small wire on the starter solenoid when cranking, correct?
What happens to the voltage on the main + terminal on the starter when the key is turned to the start position?
If you have good power to both the main + on the starter and the solenoid trigger wire, then the solenoid is bad and not transferring power to the starter motor. This does not explain why your truck died on you though so I doubt that is your problem.
