2000 blazer, 4.3 P0300 freeze frame data
Old Aug 7, 2015 | 10:39 AM
toploader9's Avatar
toploader9 is on a distinguished road
Default 2000 blazer, 4.3 P0300 freeze frame data
Hello, I have done numerous searches regarding this issue. I have look at many different things.
The symptoms just occurred on after the heavy rain. The vehicle started to miss and stumble at idle, but runs fine at higher RPM. Here is what I have found:
1. Code reader in history shows code DTC P0300, intermittent misfire.
2. Checked fuel pressure, which was 60 psi and stayed constant for over 10 min
3. Checked spark on all cylinders with timing light, cylinder #2 was inconsistent.
4. #2 spark plug wire shows 1200-1300 ohms in 2 ft, #4 is similar, #2 is about 800 and is about 1’ long
5. Checked plugs #2, #4, #6, look fine, light chocolate brown in color were changed from platinum to iridium 3 years ago.
6. Checked compression
• #2-150 #1-148
• #4-148 #3-150
• #6-150 #5-148
7. Checked cap and rotor, all looks fine, very little corrosion, were changed 3 years ago.
Put it back together and started it up
1. Idles fine when cold
2. Using the timing light #2 looks the same as the others good consistent spark, consistent no blackouts
3. Revs well and is smooth
4. Once up to temperature the stumble and miss returns
5. Check #2 with the light the spark again was inconsistent with #4 being normal
6. Checked codes, with none present.
Parts changed Aug 1/15
1. Changed wires, plugs, cap and rotor. All GM
2. Checked EGR, looks fine and changed gasket
3. Changed fuel filter because it needed changing.
4. After changing the wires, the idle was bad. Checked the plug boots, there was too much dielectric grease in them. Cleaned that out. Idles OK, but there still is a miss. It seems like I am at the same point I started with.
5. Checked the coil for any issues, the high side is around 5500ohms and the low side is about 0.7ohms.
6. Code DTC P0300 still showing, the freeze frame data in open loop are:
• TPS 0.0
• Fuel system 1 OL
• Fuel system 2 OL
• Calc load 6.3
• ECT (F) 79
• STFT B1 % 7.8
• LTFT B1 % 7.8
• STFT B2 % 6.3
• STFT B2 % 7.8
• Map inHG 12.1
• RPM 895
• Vehicle speed 0
• MAF lb/min 1.4
7. Here is the closed loop data
• TPS 0.0
• Fuel system 1 CL
• Fuel system 2 CL
• Calc load 0
• ECT (F) -40
• STFT B1 % -100
• LTFT B1 % -100
• STFT B2 % -100
• STFT B2 % -100
• Map inHG 0
• RPM 0
• Vehicle speed 0
• MAF lb/min 0.0
The closed loop freeze frame data does not make any sense.
Old Aug 7, 2015 | 08:37 PM
Ricco's Avatar
Ricco is on a distinguished road
What the temperature in your area? Ur freeze time is showing - degrees plus rpms and many other inputs are missing. Perhaps at some point ur loosing connection? Did you check ur ecm connectors? If possible run a live data scan and carefully start moving sections of the wiring harness. Start by the ecm and all around the firewall towards the sensors. Mine had a short that was intermittent and thats how I found it. Best of luck
Old Aug 19, 2015 | 07:53 AM
toploader9's Avatar
I took the blazer to the dealer and the problem was that I had #4 and #6 plug wires reversed after I had pulled the distributor.
Old Aug 19, 2015 | 01:09 PM
Ricco's Avatar
Thanks for sharing , glad the problem got solved.
Chevy33
Aug 8, 2014 07:42 PM
Denominator
Jan 2, 2012 07:31 AM
keeslinger31
19
Dec 25, 2011 09:58 AM
blazer#3
Apr 13, 2009 09:56 PM
joethejman4us
Oct 12, 2008 08:20 PM
