2000 Blazer 4.3L fuel delivery problem
Hi guys, have a question.
I have a 2000 Blazer with the 4.3L with the "spider" injection system. Fuel pump is working, but according to gauge I only have exactly 60 psi. I already checked fuse, relay, spark...I'm not sure what it's problem is.
If anyone has dealt with this please let me know. I'd like to get it fixed soon. Tries to turn over but doesn't hit. Is it a fuel pressure issue even at 60 psi?
Key on, engine off, fuel pump running, pressure must be 60psi to 66psi. It must remain above 55psi for at least 10 minutes after the pump shuts off. 60psi is borderline, but it should still start. Might want to check spark. Pull the coil wire from the distributor, prop it up one half inch from ground and crank the starter. Should be a rythmic blue, not orange, spark.
The "Security" light should be off with the ignition on, and when cranking. If Passlock detects a "theft situation" the BCM commands the PCM to disable the fuel injectors. A capable scan tool is necessary to access and retrieve the body codes from the BCM. The DTC's start with "B", and a powertrain scan tool will not access them.
It's listed almost just like that. No codes stored or pending.
Then the problem is with Passlock. It is disabling the injectors, and a possible theft situation was/is detected. You'll need to access the Passlock module to find out what the problem is. The most common problem is the sensor at the ignition lock cylinder does not recognize the key you're using.
EDIT: Most auto parts stores either have it in stock, or can order it: http://www.dormanproducts.com/gsearc...word&q=924-713
