2000 Blazer 4x4 module or motor??
Old Sep 5, 2013 | 04:35 PM
sky_blazer's Avatar
sky_blazer is on a distinguished road
Default 2000 Blazer 4x4 module or motor??
what are some ways to determine what is wrong on my 4 wheel drive module or shift motor? i have the 233 TC (3 button selector), i already replaced the vacuum switch and the actuator looks to be working right. when i push 4hi i hear it start to engage, then all lights go out on my selector. i tried putting it in reverse and the truck didnt even move, further more i put it in park and i heard a grind noise after a few starts i finally did get it back in 2wd by pushing 2wd button i heard a clunk and 2wd lit up on my selector. is my shift motor bad?
forgot: the lights flash indicating the selector works every time i turn key but all go out after
Old Sep 5, 2013 | 05:27 PM
warthogdriver's Avatar
In the tech section there is a thread to help diagnose 4x4 issues.
sounds like it is not engaging though.
Old Sep 5, 2013 | 06:41 PM
sky_blazer's Avatar
the tag on the back of the TC reads "New Process Gear 233-C" how hard is it to replace the motor?
Old Sep 6, 2013 | 01:13 AM
Spree's Avatar
Spree is on a distinguished road
I wouldn't think the TC is bad....keep checking! My blazer did some funky things when the switch (3 button selector) went bad. Soldered the switch back to the circuit board and everything was fine after that.
Old Sep 6, 2013 | 07:41 AM
sky_blazer's Avatar
UPDATE: i just went out and tried it. started the truck, put it in drive, once it started rolling i shifted to N and pushed 4hi i heard it engage and could feel it in the truck, both 2hi and 4hi were lit up on my selector. i shifted to N again and pushed 2hi, both 4hi and 4lo blinked 4-5 times then 2hi lit up. i could hear it disengage. thoughts?
Old Sep 6, 2013 | 02:07 PM
sky_blazer's Avatar
any suggestions??
Old Sep 8, 2013 | 09:02 AM
sky_blazer's Avatar
bump....
Old Sep 8, 2013 | 12:28 PM
spittybays
Guest
Posts: n/a
Old Sep 8, 2013 | 05:27 PM
sky_blazer's Avatar
Originally Posted by spittybays
UPDATE: thanks for the info brother. i tried it again (rolling) it started to shift then lights went out again, no reverse at all, put in drive and grinded under truck. i quickly shut motor off, and jumped the pins on ALDL. got DTC 2 on transfer case, advice please
Old Sep 8, 2013 | 07:48 PM
spittybays
Guest
Posts: n/a
Not a unit repair guy. Anybody else?
