2000 blazer 4X4 not engaging
Old Jan 10, 2009 | 09:09 AM
dthubley's Avatar
dthubley is an unknown quantity at this point
Default 2000 blazer 4X4 not engaging
Hello all,
This is my first post..... i have read hundreds of post alot the same but still have my problem. Here the low down... 2000 blazer 4X4 lights work like they should. Front drive shaft spins had the battery out actuator pulls in about half way still no 4X4 replaced cable put pliers on the cable and could only pull the cable about a quarter of a inch so i pulled front right axel and put in a new washer kit. Put back togeather same thing cant manualy pull the diff fork any suggestions thanks in advance.The gearsseem to be good insideI am pulling the front axel again to day
Old Jan 10, 2009 | 09:40 AM
Default RE: 2000 blazer 4X4 not engaging
Could you engage it by pulling on the shift fork in the front axle tube? Does it make any difference if you are turning a wheel while you try to engage it?
Old Jan 11, 2009 | 11:31 PM
dthubley's Avatar
Only once could i pull out the shift fork and put a pair of vice grips on to hold it out seemed to work. yes i tried turning the wheels as well. I pulled it apart again, and it seems as the casting is jamming up the fork, the hole for the fork sort of looks oblonged. I think the diff has had it ...So here is my next delemma... I got a used front diff from a guy but before I buy it how can i tell if it is the same gear ratio as i take out? Will it tear out the diff if they are different??this one is out of a 96 jimmy it looks the same execpt the two axels have plates on the ends which i can probley pop out and put in my cv joint axels ?? mine is a 2000 blazer with 370000 + KMS on it or 230000 miles..... every thing else still works fine....
Old Jan 12, 2009 | 07:35 AM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
no time right now but....GM Washer fr. diff. kit. jerry
Old Jan 12, 2009 | 08:21 AM
You will definitely tear something up if the gear ratios are different. If you cannot check the RPO codes off the donor vehicle, then you will need to engage the front axle and spin the diff. If you hold one axle output stationary, then spin the other twice, counting the turns of the pinion shaft, you will get the gear ratio.
seriosbrad
Nov 7, 2015 09:08 PM
BlueRhino
Jan 28, 2015 06:14 PM
rednekk
Dec 22, 2010 10:00 AM
kevin7144
Feb 23, 2010 05:05 PM
I8URVTEC
Jul 28, 2005 06:56 PM
