2000 blazer cylinder 6 misfire need help
Old Dec 22, 2010 | 07:32 PM
bmx4life218's Avatar
bmx4life218 is on a distinguished road
Default 2000 blazer cylinder 6 misfire need help
hey guys i got a 2000 blazer and i cant figure it out. A few weeks ago my blazer went under water and died. when i got it out it would crank but no start, i pulled the plugs and changed the oil and let it crank over to dry out. i got it started but it was running rough so i went and got the codes ran and they said cylinder 6 misfire. also its getting terrible gas milage, and the service engin soon light flashes on and off when driving for awhile. so i REPLACED ALL PLUGS, WIRE, DISTRIBUTER CAP, THROTTLE POSITION SENCOR, AND A NEW IGNITION COIL, AND I BROUGHT IT IN and had them put it on the fuel system cleaner. i cant figure it out and dont want to bring it into the shop any suggestions thanks.
Old Dec 22, 2010 | 07:40 PM
Have you tested the compression? Maybe you hydro locked the engine and damaged the #6 piston and/or valves.
Old Dec 23, 2010 | 07:51 PM
the compression is the same as all other cylinders and no loss of power at all when driving or pulling
rrk03300
Nov 15, 2012 10:29 PM
chevychallenged
Apr 5, 2011 07:20 AM
mbar
Nov 10, 2010 02:39 PM
hunterman18
13
Jun 22, 2010 07:55 AM
jmatt07
Dec 18, 2009 09:48 AM
