2000 Blazer engine harness diagram?
Old Jul 6, 2010 | 09:49 AM
nicocide's Avatar
nicocide is on a distinguished road
Default 2000 Blazer engine harness diagram?
Can anyone help me as where to find a engine harness diagram for a 2000 chevy blazer with a 4.3 vortec. I recently had to replace a head gasket and am wondering if I connected all the plugs back in the right spot because now it won't crank.
Old Jun 3, 2011 | 12:31 AM
85evo's Avatar
85evo is on a distinguished road
Did you ever find the diagram? I'm experiencing the same problem and I got 1 connector without a home and can't find it. I thinking that's why it won't start.
Old Jun 3, 2011 | 11:35 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
can you take a pic of the plug? they are all shaped different so even people like me can get them hooked up right.
Old Jun 3, 2011 | 09:52 PM
85evo's Avatar
it comes out of the main wiring harness, it's not part of the air filter system nor throttle body. It's closer to the driver's side as you can see on the picture.
Thanks for your help
Old Jun 4, 2011 | 10:55 AM
kevlar974's Avatar
kevlar974 is on a distinguished road
I just pulled the valve covers on my 2000 today and I think I removed that same wire it was the temp. sensor in the drivers side head just above the spark plugs. hope this helps.
Old Jun 4, 2011 | 11:24 AM
85evo's Avatar
Thanks, I didn't see because I guess when they did the heads at the machine shop it broked off and only the screw in part of the sensor was left. Will that cause my engine not to start as if its not getting spark???
Old Jun 4, 2011 | 08:03 PM
zeedeevil21's Avatar
zeedeevil21 is on a distinguished road
How about the oil pressure sensor next to distributor
Old Jun 4, 2011 | 09:44 PM
kristoph30's Avatar
If the computer doesnt know what the engine temp is, it wont know what the fuel mixture should be. you should have a code. That doesnt look like the oil sender to me. I think its the temp sensor
Old Jun 4, 2011 | 11:47 PM
85evo's Avatar
Yea is the temp sensor I'm going to buy a new one tomorrow and install it. I'll let you know the outcome.
Old Jun 5, 2011 | 11:24 PM
85evo's Avatar
put new sensor in still won't start. I guess is a timing issue??
