2000 Blazer Front Seat Removal
Of course you could swap the seat brackets, and splice the wires for power if you really have a lot of time and patience...
I've always had great luck using a regular hammer on those torx head bolts. Before you even put a torx bit to them, smack them 3 or 4 good hard times right on the head with the hammer. Usually that'll break them loose and you can then turn them out with a short breaker bar or long ratchet with a torx bit socket on it. I've broken 2 Mac Tools torx bits by just going right to them first without trying to "shock" them... Then just smacked the head of the bolt with a hammer a couple times, and it turned right out like nothing with the 3rd torx bit... I've swapped the seats in my 04 about 4 times and have used the same process every time, both getting the seats out of the donor junk yard vehicle and out of my rust-belt acquired 04, hasn't failed me yet.
Take some pics if you can. I have not put my seat in yet, so I can compare what you have going on to mine.
