2000 blazer fuel connecters
Old May 18, 2013 | 10:45 AM
rider22j's Avatar
rider22j is on a distinguished road
Default 2000 blazer fuel connecters
hello I am trying to replace my s10 fuel lines i have the plastic fuel connecters and the way my manual says to disconnect them is not working any tips from someone who has done it would be apreciated, I dont want to break them. thanks somebody must have dealt with these its the plastic line betwee the tank and the metal one
Old May 18, 2013 | 10:01 PM
Can you rotate/twist the connectors on the module and on the steel line? If not, the connector is seized/rusted and you'll end up breaking it and replacing the connector and steel line. If they rotate/twist freely, you'll need a fuel line disconnect tool to release the clips.
Old May 19, 2013 | 12:13 PM
rider22j's Avatar
not siezed cant make them disconnect please I cant break this have cheap tool does not work
Old May 19, 2013 | 03:32 PM
newguy's Avatar
Keep trying they will come loose, I believe you squeeze them right?
Old May 19, 2013 | 06:16 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
on mine there are 2 white tabs you have to squeeze then at the same time pull the lines off. the center 1 you just squeeze the black and pull it. off 9x out of 10 the sending unit connecters are gonna brake so be careful
Old May 21, 2013 | 07:42 AM
rider22j's Avatar
thanks trying it this morning. man i miss my 66 buick, so simple
aerovette99
46
Sep 28, 2015 10:04 AM
1998mom
Jul 25, 2013 09:43 AM
01Blaze218
Oct 13, 2011 10:05 AM
95jblaze
Aug 27, 2011 03:46 PM
FULLTHROTTLE
Nov 30, 2007 10:18 PM
