2000 blazer has fuel and spark wont start
Old Aug 29, 2007 | 07:24 PM
fast400's Avatar
fast400 is an unknown quantity at this point
Default 2000 blazer has fuel and spark wont start
OK was driving down the road other day and it just died no studder or nothing just straight shut off ... would crank and crank and back fire out the intake and exhaust .... got it towed home and looked over everything i new getting right fuel pressure, spark , and nothing ... had it towed to my garage and mech looked at it for 5 hrs replaced plugs cap rotor checked compression and timing and sensors said all fuel inj were good everything checked out said he had no clue what it is and for me to come and get it ... so im at a lost now anyone else had this he said may be distributor or engine comp? i have no clue any ideas would be great appreciated .. thanks
Old Aug 30, 2007 | 02:03 AM
Chevy Lover's Avatar
Default RE: 2000 blazer has fuel and spark wont start
I would try a new crankshaft position sensor. They can give a bad signal and actually deliver spark up to 50 deg advance during cranking causing the backfiring and no start condition.
Old Aug 30, 2007 | 07:08 PM
fast400's Avatar
big negative ... replacedcrank pos sensor and the cam sensor and still same thing happens .. any other ideas of what it could be ?
Old Aug 30, 2007 | 09:25 PM
Back to basics... you need compression, fuel to the cylinders and spark (at the right time).
So what could be missing?
sorry for answering with a question, I'm still thinking......
Have you tried disconnecting the battery for a couple of minutes, just in case it has something to do with the theft deterent system?
Old Aug 31, 2007 | 04:25 PM
fast400's Avatar
has gas spark compression ... new plugs wires cap rotor... its just out of "sync" alot of backfire out intake and exhaustseems like its out of time but it not i dont think thegarage checked that
Old Aug 31, 2007 | 04:44 PM
Sounds like the timing is off. I know you said that your mechanic checked the timing, but something doesn't sound right... Recently there was another member that somehow had the base timing in the PCM change.
Old Aug 31, 2007 | 05:07 PM
fast400's Avatar
hum is it easy enough to check timing on a blazer maybe i need to check it also
chevylover5
Dec 24, 2013 08:31 AM
1996chevyblazer
Jul 14, 2013 07:55 AM
Love/hate relationship
May 6, 2013 08:30 PM
RolliE319
Apr 10, 2013 10:29 AM
armydad71
May 3, 2010 01:48 PM
